For that you can use the native variable called PeakAndShoulderEnergy and PeakAndShoulderDemand which can be used in the UtilityCost:Charge:Simple and UtilityCost:Charge:Block field called Source Variable. To see all the variables automatically created by EnergyPlus for tariff calculations, see the Native Variables table in each Tariff Report in the HTML file.
