Check out this presentation, it has pretty much everything you need. If you are not able to create a batch to change the weather file, send me an email, I can send you an example.
Such feature exists in eQUEST. Check out this presentation, it has pretty much everything you need. If you are not able to create a batch to change the weather file, send me an email, I can send you an example.need.
