The Create Baseline Building doesn't do exactly this but does use a lot of the same logic from the openstudio-standards gem. This measure expects to have a compled model passed in. You could use the baseline measure in a workflow running after the Space Type and Construction Set Wizard measure that now also uses the openstudio-standards gem. This would set any loads, schedules, and constructions that are not altered by the baseline measure.
Of course you would add your geometry and assign space types, and I believe you also need to add an HVAC system to use the baseline measure.
The Create Baseline Building doesn't do exactly this but does use a lot of the same logic from the openstudio-standards openStudio-standards gem. This measure expects An example difference is that it won't change plug loads in your model. You also need to have pass in a compled model passed in. model. You could use the baseline measure in a workflow running after the Space Type and Construction Set Wizard measure that now also uses the openstudio-standards gem. This would set any loads, schedules, and constructions that are not altered by the baseline measure.openStudio-standards gem.
