If I understand correctly this is the outpout you need: http://bigladdersoftware.com/epx/docs/8-0/input-output-reference/page-011.html#surface-outside-face-incident-solar-radiation-rate-per-area-wm2
You can add Surface Outside Face Incident Solar Radiation Rate per Area in the Output:Variable of your idf.
