if illegal character contains in your sim file will also result in this problem.For example,if I named my project name or component name in chinese,the sim file will corrupt when I open it using SIM explorer.And I revised the peoject name or component name into English,the sim file can be opened successfully.
if illegal character contains in your sim file will also result in this problem.For example,if problem,which is I named always run into.For example,when I named my project name or component name in chinese,the sim file will corrupt when I open it using SIM explorer.And I revised the peoject name or component name into English,the sim file can be opened successfully.
if illegal character contains in your sim file will also result in this problem,which is I always run into.For example,when I named my project name or component name in chinese,the sim file will corrupt when I open it using SIM explorer.And I revised the peoject name or component name into English,the sim file can be opened open successfully.
