Design Specification Outdoor Air along with infiltration objects are a bit different from other Internal loads in OpenStudio in that they don't have an definition/instance relationship. You just drag one in from the library directly onto a space or space type. Then you can rename it and change the characteristics of the object.
There is not a dedicated button to make new object for these types of objects, the only way to make new ones is to bring them in from the library. I'll admit this isn't an ideal workflow.
