In your EnergyPlus install folder, \PreProcess\HVACCurveFitTool\CurveFitTool.xlsm Even though it is intended for air-to-air, you should be able to adjust the inputs to match water temperatures on either side.
In your EnergyPlus install folder, \PreProcess\HVACCurveFitTool\CurveFitTool.xlsm Even though it is intended for air-to-air, you should be able to adjust the inputs to match water temperatures on either side. \PreProcess\HVACCurveFitTool\CurveFitTool.xlsm
