Actually, I only used Chiller:Electric:EIR to do the modeling before. But I have a similar situation after using the chiller curves calculated by myself. So I double checked the outputs, including (from .rdd file): Output:Variable,,Chiller Capacity Temperature Modifier Multiplier,hourly; !- HVAC Average [] Output:Variable,,Chiller EIR Temperature Modifier Multiplier,hourly; !- HVAC Average [] Output:Variable,*,Chiller EIR Part Load Modifier Multiplier,hourly; !- HVAC Average [] And then, I found some weird curve feature there and figured out the issue, which is the wrong curve I calculated. Try that to see it is helpful to you.
