At some point for ZNE it moves away from "% better than code and then buy solar" to "can we stay under our solar budget?"
Your solar budget is:
24,000 sf roof * 90% roof area utilization * ~19 W/sf (assuming flat, high-efficiency panel) * (1 kW/1000 W) * 1,100 kWh/kW-yr = ~450,000 kWh/yr, or a roof production of 62 kBtu/sf-yr.
If you have 7 floors, that means your overall EUI target for the building is about 9 kBtu/sf-yr.
This will be very difficult to hit. You need more energy production. Some ways to do that are:
  • Elevate solar above roof, to get full area (increases target to ~10 kBtu/sf-yr)
  • Add solar to facades /shading / canopies
  • Figure out another energy source
I think you may be able to get down to ~20-25 kBtu/sf-yr through energy efficiency measures.
"Mandatory" measures:
  • All LED lighting
  • Energy Star Tier 3 appliances (refrigerator, dishwashers, etc.) + induction cooktops
  • Lots of insulation, good windows
Also consider:
  • Solar hot water heating
  • Heat pump water heater
  • Drain Water Heat Recovery
  • Sewer line-integrated heat pump/heat recovery
  • Compact Hot Water Distribution
  • Low-flow showers, common laundry
  • Each unit gets a Heat Recovery Ventilators instead of bathrooms exhaust fans for ventilation, with spot boosting for kitchen range hoods.
  • VRF heating/cooling or central heat pump serving baseboard hot water loop in each unit (+mass and radiant if you have the $)
  • Ceiling fans provided for each unit
  • Hit a target infiltration rate with airborne sealant deposition. (Aeroseal, the duct sealing company, now provides a service to seal multifamily units and hit a guaranteed infiltration rate. <1 ACH50 infiltration).
California is requiring all new homes to be ZNE in 2019, including multifamily (I'm not sure how they handle multi-story buildings): http://www.californiaznehomes.com/
You can see a list of the measures they are considering for this in presentations here: http://title24stakeholders.com/meetings-workshops/
