You can get the Electricity:Facility as a timeseries data, using Output:Meter, and then process that into those variables. Also report out the Schedule Value for the schedules that define when it is peak time, they can help you sort between Peak* and OffPeak*. Demand power is just the Joules from the meter divided by the reporting interval duration in seconds, but this is more accurate for the finest resolution data you can get. TotalDemand also includes a definition for a sliding average window that is often less than an hour. So if you want to be able to replicate the values reported by the tariffs, you will need to use at least timestep fequency data rather than hourly.
