Open your OSM file->run->5-EnergyPlus-0->eplusout.rdd. Copy the variable name into the AddOutputVariable Measure. You can also open the eplusout.rdd file in the term Run Simulation->Tree. After opening the file, copy the variable name into the AddOutputVariable Measure.
