The last input to the ElectricEquipment
object allows the energy use to be included in a unique sub-category name at your choosing (e.g., OfficeElecEquip, KitchenElecEquip, DataCenterElecEquip, etc.). The Lights
object also used this same input (4th input from end of object).
ElectricEquipment,
A1 , \field Name
A2 , \field Zone or ZoneList Name
A3 , \field Schedule Name
A4 , \field Design Level Calculation Method
N1 , \field Design Level
N2 , \field Watts per Zone Floor Area
N3 , \field Watts per Person
N4 , \field Fraction Latent
N5 , \field Fraction Radiant
N6 , \field Fraction Lost
A5 ; \field End-Use Subcategory
\note Any text may be used here to categorize the end-uses in the ABUPS End Uses by Subcategory table.
\note The following special tags will also place the end-use in specific rows in the LEED Summary table
\note EAp2-4/5. Performance Rating Method Compliance:
\note Fans-Parking Garage, Interior Lighting-Process, Cooking, Industrial Process, Elevators and Escalators.
\type alpha
\retaincase
\default General
Lights,
A5 , \field End-Use Subcategory
\type alpha
\retaincase
\default General
object also used this same input (4th input from end of object).(.
ElectricEquipment,
A1 , \field Name
\type alpha
\retaincase
\default General
Lights,
\type alpha
\retaincase
\default General
object allows the energy use to be included in a unique sub-category name at your choosing (e.g., OfficeElecEquip, KitchenElecEquip, DataCenterElecEquip, etc.). The etc.).Lights
object also used this same input (.
ElectricEquipment,
A1 , \field Name
\type alpha
\retaincase
\default General
Lights,
\type alpha
\retaincase
\default General
