See if this post answers your question.The short answer is that while most materials in EnergyPlus do have a known thickness, that EnergyPlus doesn't have different ways to tag thin line geometry to a position within the wall construction such as face of stud center line, or finished surface like Revit does. There are just accepted practices such as modeling to outside of exterior walls and the centerline of interior walls. The Frame and Divider object does add more control to framing around windows.
