If your water cooled chiller is connected to a condenser loop:
Little circles will appear on the chiller. Clicking these circles will take you to the condenser loop.
If your water cooled chiller is not connected to a condenser loop:
Make sure your model has a condenser loop. Switch between loops in the model using the dropdown in the upper right of the HVAC tab. If you don't have a condenser loop in the model, use the green +
button to either:
- Create a blank loop and add a cooling tower, pump, and setpoint manager, or
- Create one of the template systems that has a condenser loop and delete the extraneous other loops. This method has the advantage of having the loop already set up.
Next, select your condenser loop and connect your chiller:
- Click
My Model
in right column - Click
Chiller Electric EIR
- Drag the chiller that's already in your model onto the demand (bottom) half of the condenser loop
- You should now see the circles on the chiller indicating that it is connected
