Here's a list of the resources I would investigate:
- ANSI/ASHRAE/IES Standard 90.1 Appendix A
- ASHRAE Handbook of Fundamentals, Chapter 18, Table 18
- ASHRAE Handbook of Fundamentals, Chapter 26, Table 1
- COMNET Appendix D - Construction Materials
- OpenStudio Standards
- The Building Component Library
The materials in (2) are available in the OpenStudio via:
- The On Demand Template Generator
- OpenStudio library files (File > Load Library).
Also, the OpenStudio API can be used to get components from the BCL. See these previous questions for more information:
- https://unmethours.com/question/16992/how-do-you-search-local-bcl-components-using-api-with-c-bindings/
- https://unmethours.com/question/8141/insert-component-from-bcl-with-ruby-api/
- Download from the Building Component Library directly or through the OpenStudio app (Components & Measures > Find Components).
- The
On Demand Template Generator - OpenStudio library files (File > Load Library).
app (Components & Measures > Find Components).app.
- The OpenStudio library files (File > Load Library).
- Download from the Building Component Library directly or through the OpenStudio app.
- OpenStudio
StandardsStandards
