From the INPUTS sheet...
DX Coil Type = Other
Independent Variable = Flow or Temperature (either will work)
Curve Type = Quadratic
For the independent variable, either option will work as long as the corresponding column in the performance data is PLR.
The performance data header names are less important than getting the dependent and independent variable data in the correct columns.
