@ethankheil, I wasn't able to reproduce the Gross Wall Area issue on may Mac with 1.13.0 installed with your model. Below is also image of end use breakdown so you can compare it against your run.
Trying to figure out what might be different for your run. An unlikely cause is the operating system.
Another thought is to confirm that the correct version of EnergyPlus is being used. Look for any additional versions of EnergyPlus in the show tools dialog and delete versions of EnergyPlus that are not contained within OpenStudio.
One last idea is to inspect the IDF to see if it looks valid and then manually run it in EnergyPlus.
