Lets assume you have an OSM model that is has measures associated with it (you added them in the "measure" tab of the OpenStudio application as opposed to using "Apply Measure Now" ).
  • If you load this model into PAT as the baseline model then it will bring in all of the measure that previously where in the "measures" tab of the OpenStudio application. They will be "Always Run" measure in PAT.
  • But if you instead load that model as a design alternative, you are correct, only the OSM model content comes in, and not any measures that were associated with it.
