You could do it using Regex. The downside is that you might have to adapt your regex for each type of surface. For your example you could use BuildingSurface:Detailed,\r\n(.*.)\r\n(.*.floor.*.)\r\n(.*.) in the search field and Floor:Detailed,\r\n\1\r\n\3 in the replace field. Then for a wall you could replace .*.floor.*. by .*.wall.*. and Floor:Detailed by Wall:Detailed.
