Option two is to set OpenStudio to use Radiance for the daylight calculation. By doing this, you can look at daylight distribution across zones, and even across concave floor plans. The catch is that this will only provide the dayLIGHT results; the thermal effects are still bound by the EnergyPlus calculation.
