The setup you are using now is a gas heating coil and a fan sitting independently on an air loop. The fan knows nothing about how the coil is operating. You would need to incorporate a cycling fan system in your model (i.e., 'AirloopHVAC:Unitary:Furnace:HeatOnly'). With this system type you can choose to run the fan continuously or cycle the fan with the coil operation.
