It looks like you have set both the min and max OA flow to 153 cfm, causing a constant OA flow whenever fresh air is needed. Since you have autosized the supply flow rate, there's a chance that EnergyPlus is calculating a supply flow less than your hard-sized OA flow. Check the Outdoor Air Summary report and the HVAC Sizing Summary report to see if this is the case.
It looks like you have set both the min and max OA flow to 153 cfm, causing a constant OA flow whenever fresh air is needed. Since you have a CV fan in the air loop, the air loop will always supply air at the same flow rate (whether it's autosized or hard-sized). So, constant OA flow and constant supply flow will yield constant OA fraction. If you were to hard-size the supply flow rate, there's then that would just alter the OA fraction to a chance that EnergyPlus is calculating a different value than the 40% you're currently seeing when autosizing the supply flow less than your hard-sized OA flow. Check the Outdoor Air Summary report and the HVAC Sizing Summary report to see if this is the case.rate.
