One thing that might be useful to know is that low-flow radiant systems in EnergyPlus don't follow the heating and cooling setpoints in the zone's thermostat. Instead, they follow the setpoint schedules defined inside the radiant systems themselves. Because of this quirk, you may be able to just use the approach of modifying those setpoint schedules as you originally thought.
