You can export single variables with the "Export Output Variable to csv" measure, and export single meters with the "Export Meter to csv" measure, available on BCL.
More detail on applying these is described in this unmet hours post
If you have several variables, use Julien Marrec's "Output Variables from csv" measure, which reads a list of output variables you would like from a csv file, also available on BCL.
On the unmet hours slack channel, Andrew Parker posted the DView measure, which will take the output variables you've requested and put them into a .csv file that can be read by DView for visual analysis.
