While most of the data in the standard OpenStudio results come from tabular data, it does use hourly time-series data for zone temperatures and relative humidity. You can see this in the Zone Conditions Section where the 8760 values are binned by temperature for each zone.
If you want to see each value, you can open the SQL file from the simulation in ResultsViewer.
You can also create a custom report to generate a chart for each month with the data processed how you want it.
