While you are able to set the Outside Boundary Condition Object to the name of the SurfaceProperties:OtherSideCoeffients object it does not applies to windows or glassdoors.
The rules are complicated, from the EnergyPlus InputOutputReference 8.5 for the FenestrationSurface:Detailed object:
If the base surface has Outside Boundary Condition = Surface or OtherSideCoefficients, then this field must also be specified for the subsurface. Otherwise, it can be left blank.
If the base surface has Outside Boundary Condition = Zone, then this surface retains that characteristic and uses the same zone of the base surface. It can be entered here for clarity or it can be left blank.
If Outside Boundary Condition for the base surface is Surface, this field should specify the subsurface in the opposing zone that is the counterpart to this subsurface. The constructions of the subsurface and opposing subsurface must match, except that, for multi-layer constructions, the layer order of the opposing subsurface’s construction must be the reverse of that of the subsurface.
If Outside Boundary Condition for the base surface is OtherSideCoefficients, this field could specify the set of SurfaceProperty:OtherSideCoefficients for this subsurface. If this is left blank, then the Other Side Coefficients of the base surface will be used for this subsurface. Windows and GlassDoors are not allowed to have Other Side Coefficients.
While you are able to set the Outside Boundary Condition Object to the name of the SurfaceProperties:OtherSideCoeffients object it does not applies to windows windoows or glassdoors.
While you are You should be able to set the Outside Boundary Condition Object to the name of the SurfaceProperties:OtherSideCoeffients object it does not applies to windoows or glassdoors.
The but the rules are complicated, from complicated. From the EnergyPlus InputOutputReference 8.5 for the FenestrationSurface:Detailed object:
