I would take a look at the HeatExchanger:AirToAir objects in EnergyPlus (documentation HERE).
The HeatExchanger:AirToAir:SensibleAndLatent object is frequently used to approximate a sensible only run-around coil by setting the latent effectiveness to zero. You might check out the following posts for some additional insight on the use of this object...
Modeling run around loop in openstudio
