I use an interface of Energy Plus (Design Builder). Design Builder includes an internal calculation engine for CFD calculations. You can export the airflownetwork results and radiant temperature results of E+, and use them as limit condition inputs. Then you can make a CFD simulation and can view Airflow between zones in EnergyPlus.
Hi.
I use an a interface of Energy Plus (Design Builder). Builder).
Design Builder includes an include a internal calculation engine for CFD calculations. calculations.
You can export the airflownetwork results and radiant temperature results of E+, and use them it as limit condition inputs. inputs.
Then you can make a CFD simulation and can view Airflow between zones in EnergyPlus.EnergyPlus
