You should be able to drag the construction from the library in the 'Constructions' tab in the OS application.
If it's not there try loading another example model via File->Load Library or in the SketchUp plugin using the 'Space Type and Construction Set Wizard' script found under 'On Demand Template Generators'.
If it's not there try loading another example model via File->Load Library or in the SketchUp plugin using the 'Space Type and Construction Set Wizard' script found under 'On Demand Template Generators'.Generator' script.
