The problem with minimum temperature difference is a bug that should be fixed in version 8.6. With the bug, conditions could get stuck in mode where neither the chiller nor HX would run. With the fix the chiller and HX use the minimum delta temperature tolerance in the same way to decide which should run.
Thanks to Chandan Sharma for pointing out the tricky one-line fix.
