It seems that the timestep lag in passing data with bcvtb is an intentional part of the design of the co-simulation capability. The lagging makes the computing safer and more robust. Although you can shorten the timestep used to decrease the impact of the lag in data transfer, there is no way to remove the lag and get full communication within a single timestep.
