This sort of thing will happen if you have thermostat (and humidistat) schedules that have setup/setback or internal gains with "top hat" schedules that create an abrupt changes in zone loads. The HVAC system will attempt to recover from a change in loads over just one timestep, which takes more power for a shorter timestep. Such an experiment would need to use constant thermostat schedules and gradually ramping changes in internal gains.
This sort of thing will happen if you have thermostat (and humidistat) schedules that have setup/setback or internal gains with "top hat" schedules that create an abrupt changes in zone loads. setup/setback. The HVAC ideal loads system will attempt to recover from a change in loads over just thermostat in one timestep, which takes more power for a shorter timestep. Such an experiment would need to use constant thermostat schedules and gradually ramping changes in internal gains. schedules.
