You'll need to provide more information from E+.
In OpenStudio, on the "Run Simulation" tab, click on the "Tree" tab at the top, and expand the tree. It's going to show you a lot of files - you are looking for the eplusout.err file. You may also want to check the *stderr file...
This file will detail all the errors & warnings in your model, and can be opened with any text editor. Once you find the file and open it, do a search for the word "Fatal" and this should direct you to the error that is causing your simulation to crash.
Unfortunately, without the error messages in your eplusout.err file, we can't help you diagnose the problem.
In OpenStudio, on the "Run Simulation" tab, click information. Click on the "Tree" tab at the top, and expand the tree. It's going to show you a lot of files - you are looking for the eplusout.err file. You may also want to check the *stderr file...
