The really good news is that this task will be much easier with the OpenStudio Command Line Interface (CLI) coming out soon.
However, for your current script I think you may be calling the wrong version of the create method. I think you want to call this version of the create method:
/// Creates a Job tree from the current workflow
/// \param[in] outdir Output directory to be applied to the first job in the Workflow (child jobs inherit the outdir)
/// \param[in] infile Input file to be attached to the first job in the workflow
/// \param[in] epwdirorfile EPW file or directory containing EPW files to be search when looking for the appropriate
/// EPW for energyplus simulation of infile
/// \param[in] t_url_search_paths paths to search while normalizing any URLs in IDFs or OSMs that exist in the workflow
openstudio::runmanager::Job create(
const openstudio::path &outdir,
const openstudio::path &infile,
const openstudio::path &epwdirorfile = openstudio::path(),
const std::vector<openstudio::URLSearchPath> &t_url_search_paths = std::vector<openstudio::URLSearchPath>());
