Export the idf from OpenStudio and run the simulation with EP-Launch (on Windows or equivalent). The output variables and meters will be output to the eso output file and converted to csv automatically. Apparently OpenStudio doesn't save the eso output file? If it did, you could run the readvarseso postprocessor on it to convert to csv.
Export the idf from OpenStudio and run the simulation with EP-Launch (on Windows or equivalent). The equivalent) the output variables and meters will be output to the eso output file and converted to csv automatically. Apparently OpenStudio doesn't save the eso output file? If it did, you could run the readvarseso postprocessor on it to convert to csv.
