You can cast the ConstructionBase to a Construction by using to_Construction:
construction = surface.construction
if not construction.empty? and not construction.get.to_Construction.empty?
construction = construction.get.to_Construction.get
end
Which is one way to do it.
You can cast case the ConstructionBase to a Construction by using to_Construction:
end
