It appears that when you call addToThermalZone on the HPWH, OpenStudio assumes sets the compressor location, etc, to be zone-based. This happens here in the source code.
To fix this, try moving the line hpwh.addToThermalZone(zone) into the if block.
To fix this, try moving the line hpwh.addToThermalZone(zone) into the block.ifelse
It appears that when you call addToThermalZone on the HPWH, OpenStudio assumes sets the compressor location, etc, to be zone-based. This happens seems to happen here in the source code.
To fix this, try moving the line hpwh.addToThermalZone(zone) into the else block.
