hello, try doing the simulation in this way: 1.open your final model with shading surfaces (overhangs) 2.save your model with .idf format 3.do not do the simulation with OpenStudio, run directly with EnergyPlus 4.then the simulation and when you have the results, open again the .idf, the overhangs will be there
