During unoccupied hours the outdoor air damper should close and then the unit should cycle on and off to meet the setback setpoint. To meet the setpoint, the heating and cooling coils should also turn on and off.
If you are using EnergyPlus/OpenStudio I can show you exactly how to do this, if you are using another program tell everyone and I am sure someone will know.
