A good place to start to diagnose what is going wrong with the zone heat balance is to examine the time series results for the output variables that are called "Zone Air Heat Balance xxx." These roll up the heat balance terms for each zone and when compared to each other can often help reveal where things are going wrong. Since this is halting before warmup is complete you would need to turn on reporting during warmup using (Output:Diagnostics with ReportDuringWarmup).
