(updated 2016.07.26) It is absolutely possible to change the reflectance of the room surfaces in your OpenStudio model. This is explained in the second 'graph, below.
Again, if using Radiance directly, the simplest method is to use a plastic material, and equal RGB values to define a grey material of n reflectance, definition e.g.:
void plastic my_60%_reflective_material
0 0 5
0.6 0.6 0.6 0 0
As you state you are using OpenStudio, then you'd want to make an opaque material whose absorptance is the inverse of the reflectance you desire, and place that on the innermost layer of your construction. (This will be translated to a similar plastic material definition in the corresponding Radiance model, when you run the Radiance measure in OpenStudio.)
The safest thing to do would be to locate the material(s) you are already using for your interior room surfaces and modify their absorptances to get you the reflectance you want. The screenshot below shows the material properties for 1/2" Gypsum, from your model (thanks for posting that); it's got a Visible Absorptance of 0.40 (see lower right), meaning it's a 60% reflective material, in the visible spectrum. If you change this value to the inverse of whatever you want for visible reflectance, you're all set. You can duplicate that one as many times as you need to get all the different values you desire. Then you'd apply this material as the innermost layer in your constructions, and that's it.
Now, as for the shape of the floor plan: it's non-convex. This is problematic both for EnergyPlus (shading calculations), and unfortunately for Radiance as well, at least in the OpenStudio / Radiance implementation. The illuminance maps, which you will use for your daylight evaluation, must be rectangular; OpenStudio does not (easily) support arbitrarily shaped lighting calculation grids. You will not be able to cover the entire area of your floor plan with uniformly arrayed calculation points. You can either place illuminance maps to cover what you can and evaluate relative changes in your designs, but obviously, the daylight metrics will not be spatially representative.
Hope this helps!
Again, if If using Radiance directly, the simplest method is to use a plastic material, and equal RGB values to define a grey material of n reflectance, definition e.g.:
0 0 5
0.6 0.6 0.6 0 0
As you state you are If using OpenStudio, then you'd want to make an opaque a material whose absorptance is the inverse of the reflectance you desire, and place that on the innermost layer of your construction. (This This will be translated to a similar plastic material definition in the corresponding Radiance model, when you run the Radiance measure in OpenStudio.) OpenStudio.
The safest thing to do would be to locate the material(s) you These are already using for your interior room surfaces and modify their absorptances to get you the reflectance you want. The screenshot below shows the material properties for 1/2" Gypsum, from your model (thanks for posting that); it's got a Visible Absorptance of 0.40 (see lower right), meaning it's a 60% reflective material, in the visible spectrum. pretty generic responses. If you change this value to provide more detail (what program are you using, what's the inverse goal of whatever you want for visible reflectance, you're all set. You the simulation (pretty pictures versus good data, etc.)) we can duplicate that one as many times as you need to get all the different values you desire. Then you'd apply this material as the innermost layer in your constructions, and that's it. probably provide more details.
Hope this helps!
