The 'FanCoil_HybridVent_VentSch.idf' example file is a good one to use to test whether ZoneVentilation:DesignFlowRate and ZoneMixing are affected by zone multipliers, since it is set up with both those objects (and output variables). Let's science this:
Hypothesis: ZoneVentilation:DesignFlowRate and ZoneMixing object inputs are unaffected by zone multipliers.
Method:
  • Run unmodified example file
  • Change the multiplier for 'North Zone' in the example file, run modified file.
  • Verify that the zone design loads were affected as expected.
  • Check if the output variables 'NORTH ZONE:Zone Ventilation Standard Density Volume Flow Rate' and 'NORTH ZONE:Zone Mixing Total Heat Gain Energy' remained unchanged.
Conclusion: Hypothesis verified. ZoneVentilation:DesignFlowRate and ZoneMixing object inputs are unaffected by zone multipliers, and should be adjusted accordingly.
Method:
  • Change the multiplier for 'North Zone' in the example file, run modified file.file.
Method:
  • Change the multiplier for 'North Zone' in the example file.
  • Check if expected, yet the output variables 'NORTH ZONE:Zone Ventilation Standard Density Volume Flow Rate' and 'NORTH ZONE:Zone Mixing Total Heat Gain Energy' remained unchanged.
Method:
  • Change Method: I changed the multiplier for 'North Zone' in the that example file. Verify file, verified that the zone design loads were affected as expected, yet the output variables 'NORTH ZONE:Zone Ventilation Standard Density Volume Flow Rate' and 'NORTH ZONE:Zone Mixing Total Heat Gain Energy' remained unchanged.
