Regarding question 3.
You can create a custom meter which is a summation of ideal loads in zones.
Here is an example of a custom meter using electricity consumption in various zones:
Meter:Custom,
SuiteElectricity, !- Name
Electricity, !- Fuel Type
, !- Key Name 1
Electricity:Zone:Thermal Zone 1, !- Output Variable or Meter Name 1
, !- Key Name 2
Electricity:Zone:Thermal Zone 2, !- Output Variable or Meter Name 2
, !- Key Name 3
Electricity:Zone:Thermal Zone 3; !- Output Variable or Meter Name 3
Just change the output variable name to the appropriate ideal loads name.
As you can probably tell, I use this feature to separate out suite electricity from common areas in multi-res buildings.
Check the E+ InputOutput manual for other examples
Meter:Custom,
, !- Key Name 1
, !- Key Name 2
, !- Key Name 3
As you can probably tell, I use this feature to separate out suite electricity from common areas area electricity in multi-res buildings.
Regarding Regard question 3.
Meter:Custom,
, !- Key Name 1
, !- Key Name 2
, !- Key Name 3
As you can probably tell, I use this feature to separate out suite electricity from common area electricity in multi-res buildings.
