Thank you Yi, I managed to fix the issue by constructing the Windows under the window input section on energy plus. Apparently, exporting the IDF from the openstudio interphase caused the fenestrations to have different coordinates the the ones specified by energy plus. By anually replacing the fenestrations for windows the problem was solved
