As user @Ricardo GAllegos suggested, you need to create the 'shading:building' or 'shading:site' object. More specifically, according to 'Input Output reference guide pp.334 E+ 8.5'),
Shading:Site, PV-roof-mounted-surface, !-Name Your angle here, !Azimuth Your angle here, !-Tilt Your coordinate here, !- Starting X coordinate Your coordinate here, !- Starting Y coordinate Your coordinate here, !- Starting Z coordinate number, !-Length number, !-Height
then connect that surface to the photovoltaic Generator:Photovoltaic, PV:ZN_1_FLR_1_SEC_1_Ceiling, !- Name PV-roof-mounted-surface, !- Surface Name PhotovoltaicPerformance:Simple, !- Photovoltaic Performance Object Type 20percentEffPVhalfArea, !- Module Performance Name Decoupled, !- Heat Transfer Integration Mode 1.0, !- Number of Series Strings in Parallel {dimensionless} 1.0; !- Number of Modules in Series {dimensionless}
Look up the ShopWithPVandBattery.idf example
As user @Ricardo GAllegos @RicardoGAllegos suggested, you need to create the 'shading:building' or 'shading:site' object.
As user @RicardoGAllegos 'Ricardo GAllegos' suggested, you need to create the 'shading:building' or 'shading:site' object.
As user 'Ricardo GAllegos' suggested, suggested you need to create the 'shading:building' or 'shading:site' object.
Shading:Site,
PV-roof-mounted-surface, !-Name !-Name
number, !-Length
number, !-Height
PV-roof-mounted-surface, !- Surface Name Name
