There are several different ways to add objects to loops in OpenStudio. I typically use the .addToNode method that all HVAC Components (Pumps, Chillers, Fans, etc) have. You don't see this method in the documentation for the PumpVariableSpeed class because this method is inherited from its base class, HVAC Component.
This code should work to disconnect the existing pump and add the new one to the same place on the loop:
# Get the nodes before and after the existing pump on the loop
prev_node = selected_pump.inletModelObject.get.to_Node.get
next_node = selected_pump.outletModelObject.get.to_Node.get
# Remove the existing pump. When this happens, either the pump's
# inlet or outlet node will be deleted and the other will remain
selected_pump.remove
# Get the node that remains after deleting the existing pump
remaining_node = nil
if prev_node.outletModelObject.is_initialized
remaining_node = prev_node
elsif next_node.inletModelObject.is_initialized
remaining_node = next_node
end
# Add the new pump to the node where the old pump was
if remaining_node.nil?
runner.registerError("Couldn't add the new pump to the loop after removing existing pump.")
return false
else
new_pump.addToNode(remaining_node)
end
