The best way to look at CSV files is by using a spreadsheet program like Excel or Libre/OpenOffice Calc.
You should review the RDD file to see what outputs are available for your file and request those outputs in the IDF file.
As far as load components, you might want to look at this answer:
https://unmethours.com/question/16821/energyplus-detailed-hourly-load-distribtuion/
