  1. Better documentation is on the GitHub development repo:
    • Setup: https://github.com/NREL/OpenStudio-analysis-spreadsheet
    • Spreadsheet: https://github.com/NREL/OpenStudio-analysis-spreadsheet/tree/develop/documentation
  2. As far as I know the OAS/cloud part of PAT is not functional (issue) and instead must be run from a terminal by cloning/copying the repo. Once the repo has been cloned/copied use the following folders:
    • measures - these are available for use by the spreadsheet and can be applied to the seed model during runs
    • projects - location for the spreadsheet(s)
    • seeds - seed models for runs
    • weather - location for weather file(s)
  3. The OAS is run from a terminal from the path where the repo is cloned/copied.
  1. As far as I know the OAS/cloud part of PAT is not functional (issue) and instead must be run from a terminal by cloning/copying the repo. Once the repo has been cloned/copied use the following folders:
  2. The OAS is run from a terminal from the path where the repo is cloned/copied.
    • measuresmeasures/ - these are available for use by the spreadsheet and can be applied to the seed model during runs
    • projectsprojects/ - location for the spreadsheet(s)
    • seedsseeds/ - seed models for runs
    • weatherweather/ - location for weather file(s)
