I constructed a simple system model which might address your concern.
The model has a DiscreteClock and a LineWriter.
You can find the Clock in Actors/Sources/TimedSources.
The clock fires (produces an output) every 86400 seconds.
At every tick, it causes the LineWriter to write its output to a file (ClockOutput.txt)
which must be on your file system.
Although the system model runs from 0 to 172800s with a period of 900 seconds, you can see that ClockOutput.txt has only three entries. Is that what you would like to achieve?
Notes:
- The model is at C:\fakepath\model.png.
- Please rename the model from model.png to model.xml so you can run it.
- Do not forget to specify the path to the output file (ClockOutput.txt) so the model can find it.
