- You would want to add this as an EnergyPlus measure. You could look at the Add Output Diagnostics Measure to get an idea of what it might look like.
- The Annual End Use has a pie chart of the space type makeup of your model. It is a reporting measure that pulls some tabular data form the EnergyPlus SQL file, but the space types come form the model input, specifically the OSM file.
- I may let some other people chime in with better answers for this, but you could have a reporting measure post process zones (tabular or time-series data), but as others have mentioned keep an eye out for how Ideal Air Load works, specifically lack of ventilation.
